206whp '96 GSR --- $3000!
SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD!!!
1996 Acura Integra 2dr GSR *****$3000
206whp 145tq tuned by Dave from WHIP FACTORY a couple years back
BODY
- White Diamond Pearl paintjob (Cadillac
white)
- about 100,000 miles
- JDM **** front lip
- JDM ITR taillights
- Spoon replica CF side mirrors
- shaved side moldings
- black hood
- black trunk
ENGINE
-SI PR3 head
----Skunk2 stage 2 tuner camshafts
----Omni valvesprings & retainers
----bronze valve guides
----Buddy Club cam gears
----Mugen 2 layer headgasket
- Skunk2 intake manifold TB port matched to 70mm
- Skunk2 70mm throttle body
- Precision 310cc injectors
- Aeromotive fuel pressure
regulator
- Fast-Turbo steel braided fuel lines
- Golden Eagle fuel rail
- GSR B18C block
----Golden Eagle headstud
----.25mm OS JDM B16A P30 11.6:1 compression ratio
----ARP rod bolts
----ACL main & rod bearings
----new OEM water pump
----new OEM oil pump
----CTR crank pulley
- Rage tri-y header version 1
- 2.5" test pipe
- Buddy Club spec 2 exhuast (very loud)
- HASPORT engine & trans mounts
- P28 w/ Hondata S200
- Skunk2 jumper harness OBD2a-OBD1
- Koyo half size radiator
- Samco hoses
- slim fan
- Arc radiator cap
- Spoon oil cap
- Spoon wire plug cover
- Spoon socks
TRANSMISSION
- B16A transmission
- Exedy stage 2 thin 3 puck
- ACT prolite flywheel 7lbs
SUSPENSION
- stock springs & struts
WHEELS
- LS webs with the paint stripped
BRAKES
- Hawk HP front & rear pads
- Centric force slotted rotors
INTERIOR
- JDM ITR guage cluster
- JDM ITR climate control
- Spoon shift ****
- ITR shift boot
- Sparco grey/black seats
- ITR clock
BODY
white)- about 100,000 miles
- black hood
- black trunk
ENGINE
-SI PR3 head
regulator- Fast-Turbo steel braided fuel lines
- GSR B18C block
----ARP rod bolts
- 2.5" test pipe
- Samco hoses
- slim fan
- Arc radiator cap
- Spoon oil cap
- Spoon socks
TRANSMISSION
- B16A transmission
SUSPENSION
WHEELS
BRAKES
INTERIOR
- Spoon shift ****
- ITR shift boot
- ITR clock
