~92 accord tach issue
Old Nov 11, 2009 | 09:50 PM
ChevelleSSLS6's Avatar
Default ~92 accord tach issue
fiancee's dad's car... it's a 4banger with a stick.
Sometimes the tach reads a little low, sometimes it reads high.
It doesn't go up to 4k rpm or anything crazy when he's cruising around, he says it reads about 1750rpm at idle sometimes and on the highway it'll read 1500rpm.
I'm not sure if there's some magnetic sensor near the flywheel that the tach runs off or if the tach is run old school off the distributor or if it's a cluster issue. Any help would be appreciated.
-Matt
Old Nov 12, 2009 | 11:36 AM
Default Re: ~92 accord tach issue
nobody knows what could be causing this issue, or even how the tach works (which may help in finding the issue)?
Old Nov 12, 2009 | 11:39 AM
jhammond_82's Avatar
Reject Papi
your cluster might be screwed up.
Old Nov 12, 2009 | 12:38 PM
bseriescrxsi's Avatar
its called the VSS(vehicle speed sensor) but it would throw a CEL and the speedo would also be screwing up
Old Nov 12, 2009 | 06:06 PM
that would be if the speedometer is reading wrong, right? This is the tach, aka "rpm meter".
Old Nov 13, 2009 | 07:53 AM
uberEFtuner's Avatar
The tachometer gets its signal from the distributor. Mine was acting funny(bouncing) and it was an early sign that its was dying. Once it got hot it would buck a little and the engine would die.
I bought a new one a advanced with a lifetime warranty.
Old Nov 14, 2009 | 05:51 PM
His car has trouble starting when ambient temps are warm. When it's cooler or cold, it fires right up! I know the factory intake is basically junk, but could it be due it wanting to run rich (mpgs are lower than they used to be also, he says), and being colder the engine gets more oxygen (and the fuel mix is more stoichometric) so it starts/runs better?
Seems to me that could be a intake air sensor issue with his engine. But back to the tach, the dizzy seems to be a legitimate culprit as it is well past 200k miles, 250k will have passed under that car before too long! (this is on regular oil too! but it sees mostly highway miles, with some city at each end of the ~1hr commute)
Fatcobra
Apr 17, 2007 05:20 AM
AFAccord
Jan 3, 2006 05:30 AM
stealth89hatch
13
Jun 17, 2005 03:25 PM
joenationwide
Jul 18, 2004 01:22 PM
