b2 block/b7 head
Old Nov 11, 2009 | 08:43 PM
Jenkinsal2's Avatar
Default b2 block/b7 head
I have been searching and haven't found much on this particular setup. Before anyone says its stupid I am getting this stuff from a friend and dont really have the cash to do much else at the moment. I know the b7 is obd1 and b2 is obd0. So I am asuming I will need to convert to OBD1 as well as the MPFI conversion. for this what exactly will i need?
b7 manifold/injectors/tb/
b7 head
ecu?
resistor box
b7 dizzy
harness to cut plugs from
resistor box?
Old Nov 12, 2009 | 12:45 AM
ryanevansoh's Avatar
Default Re: b2 block/b7 head
you dont have to go obd1. you can go obd0 with the obd0 injectors and an a6 dizzy and do the mpfi swap
Old Nov 12, 2009 | 04:56 AM
Jenkinsal2's Avatar
So the fact that the b7 is obd1 doesnt matter I just need to match my ecu/dizzy. That is exactly what I wanted to hear.
So then I need:
P06 ecu
obd0 injectors
resistor box
obd0 dizzy- Could I use my b2 dizzy or would I have to get the si?
Old Nov 12, 2009 | 06:15 AM
radex7's Avatar
For the OBD0 setup the ECU is actually PM6. And you are matching ECU/dizzy/injectors. You will have to modify your DPFI harness and throw in a resistor box - so, typical MPFI swap.
Old Nov 12, 2009 | 08:41 AM
Jenkinsal2's Avatar
Thanks for the correction! that could have nipped me in the butt later haha
Serdar
Apr 18, 2019 03:15 PM
ed3jose
Jun 10, 2015 04:29 PM
4g4dcruisin
Feb 1, 2010 11:51 AM
the4g4d
Jan 13, 2007 04:18 PM
EK FLY
Jul 25, 2006 09:55 AM
