99 ek front swaybatr
you can get oem ctr 26mm for like $100 from honda but you will need ctr front lca's and shock forks.
Eibach has 26mm that will bolt on to ex lca's which are much easier to come by
I found a brand new eibach front and back with all oem hardware and endlinks for $120 shipped. You just gotta look around. But theres definitely a lot of options you just gotta research as to what uoure gonna run front to back ratio for over/understeer
Like i posted before.
If you want to do a oem ctr/si 26mm you will need si/ctr lca and shock forks.
Ex is 22mm i believe and for that you will only need ex/hx front lca
Or you can get aftermarket but you will need AT LEAST ex/hx flca's
Ps theres a thread for putting si/ctr front sway using ex/hx flca but you gotta use prelude vtec endlinks and other fabbing
LFA Squad::the Godfather
Mar 26, 2007 08:05 PM
