wheel and tire question.
im lowered 2 inches right now. just picked up rota slipstream 16 by 7. yes i kno cheap rims whatever but anyways they have 205 45 16 and look dumb and tiny. i want to get a set of khumo mxs 225 50 16. will i have issues? rubbing? here of pic i found of the setup with tire and rim http://rides.webshots.com/photo/1070...28749778KKXrLr
205-55-16 is the correct tire size for our cars... I would go with 215-50-16 personally but if you really want to go 225 you can. It will look a little odd because you will have one fat sidewall... Also are you wheels 7.5 wide or more? Because if not you will not be able to run a 225!
Which is actually ok for the tire he wants to run. A 225/50/16 tire is approved for wheels as small as 6" wide to 8.5" wide. A 225/45 is approved for wheels ranging from 7"-8" on a 16" rim.
i love me some beefy tires! but im taking a big chance i dont know if im going to rub and on the ep thread josh you said anything above 215 in the rear i have to roll my fenders in the rear? im a little slow but i dont know how to do that or what it really means, im retty sure i know tho. some please show me a pic so i have an idea
ugh who ever knew tire shopping could be so hard. i just at ep hatch picture thread for rims and tires on a 2 inch drop 225 50 16 is looking good but my rear camber has to be neg so i wont rub over bumps. so do i really want to do this??
You won't rub with those tire sizes if you have the right offset.
I am running a much larger tire than that on my car and I don't have any issues.
I am pretty sure that if I can fit a 255/35R18 on a 18x8.5" +40mm offset on my car without any clearance issues then you can easily run a 225/50/16 on a 16x7" wheel under +35mm offset.
I am curious as to why are you are running such a small wheel??
Also, negative camber is good for handling, but not too much...
I am running factory spec camber settings on my car and the RSX wheel well is a bit larger but the cars are based off of the same chassis. There will be slightly less clearance on an EP3 than there is on an RSX but not much difference. If I am able to run an aggressive setup as I am running you can do nearly identical setups but with slightly less offset and width. I should have about 1/2" more clearance than you will.
the offset is 40 i believe thats what it says on the inside of the rim. im new to all this offset and wider tires stuff i just want to stick better and handle better then stock
