Transmission & Drivetrain Gearboxes, Differentials, Clutches
Slipping while driving
Old Nov 11, 2009 | 04:47 PM
stevenDAtegra's Avatar
Default Slipping while driving
A few days ago on the highway I noticed my car was starting to bounce and then all of a sudden in 5th my rpms' went up and the car wasn't going anywhere. I pulled over and inspected everything and it all looked ok so I started to drive slowly in the slow lane figuring I just maybe hit a bump and it threw off my linkage.
The whole car started to do the wobbling feeling again just once and then was normal for the 20 miles I had to go. The next day, it started doing it consistently. I always pushed the clutch in and the car would bounce more. If I don't push in the clutch and let the rpm's rev up, it eventually goes normal again and catches.
Does this seem like a clutch problem? I don't think a clutch would cause the car to shake unless it's grabbing and not grabbing quickly? There is also some noise I can hear, sort of like clanking and it only does it when it's slipping.
I also tried replacing the passenger axle since the boot was ripped and some grease flew out but that didn't obviously help
Thanks for any replies
Old Nov 11, 2009 | 05:04 PM
Aquafina's Avatar
Default Re: Slipping while driving
If its free revving, replace the clutch.
Old Nov 11, 2009 | 05:25 PM
So is the car wobbling from "clutch chatter". What throws me off is that the car still wobbles when the clutch is disengaged and I am slowing down to a stop without the brake. I guess shaking would be a better term
Old Nov 11, 2009 | 05:35 PM
Aquafina's Avatar
Clutch isn't fully disengaging or you have another problem (axles, suspension, alignment, wheels/tires/brakes).
Old Nov 11, 2009 | 05:46 PM
I'll have to try adjusting my clutch cable tomorrow. Hopefully the cable is just too tight but if it is my clutch that is slipping, I hope the damages isn't too bad because it has slipped about 10 times for about one second intervals each time.
Thanks for the quick replies, you've helped me out a few times.
underpressure02
Apr 23, 2006 06:51 PM
envious1320
Jul 9, 2005 09:47 AM
AndyD
Sep 24, 2002 03:16 PM
M.A.R.C.
Jul 21, 2002 08:57 PM
