94 rear disc conversion minimum parts.
Old Nov 11, 2009 | 02:31 PM
chikin pickle's Avatar
Default 94 rear disc conversion minimum parts.
Ok so I rolled down to the junkyard for some odds and ends. I found a '94 with something I am coveting. Rear disc brakes. Now before everyone starts bitching at me about beating a dead horse here is what I want to know. Can I get away yanking only the hub assembly? Can I make a frankenstein suspension? The vehicle in question looks identical to my suspension. rear upper arms etc. I'd rather not have to drop the crossbar on a car held up by stacks of steely rims.
Old Nov 11, 2009 | 04:50 PM
nus_dogg's Avatar
Default Re: 94 rear disc conversion minimum parts.
I believe you'll need to get both rear trailing arms, rear knuckle w/ hubs, rear calipers, e-brake cables, etc. There's more to it.
Project Low key did a DIY on this in the Modified Mag a while back.
Old Nov 11, 2009 | 05:23 PM
Ive seen the write up and I'd rather not have to pull the whole thing down off a car. Anyone done this know what I can leave out?
Old Nov 11, 2009 | 07:41 PM
BBallz24's Avatar
My scanner isn't working so I can't scan the picture Modified Mag used for Project Low Key. They say all you need is the complete rear hub/brake assembly and parking brake cables. Honda Tuning did the same swap but used the whole cross-member. I like the idea of cross-member as well because it will come with the rear sway bar. Honda Tuning also mentioned 40/40 prop valve and master cylinder.
Going Shoeless
If you can find the magazine, it is August 2008
Old Nov 11, 2009 | 09:21 PM
Thats what I'm trying to find out. Basically I want to ditch everything I can reuse from my old suspension. I'll probably pull the rear crossmember for the rear sway bar.
Old Nov 12, 2009 | 11:33 AM
BBallz24's Avatar
The picture in Modified Mag shows the rear lower control arm (I think) and everythign from the dust shield out. Then the brake cables.
stryker gs
Suspension & Brakes
14
Dec 19, 2012 05:27 PM
88 EF Hatch
Suspension & Brakes
Mar 3, 2009 06:22 PM
scobaru
Suspension & Brakes
Mar 18, 2007 09:06 PM
footmans
Aug 25, 2004 11:52 AM
