Passenger door will not open inside or out????
Alright so the car is a 93 DB2. Passenger will not open from outside or inside. I already took off the door panel even though it was closed. The automatic locks work because i can see it moving. Both rods connected to the handle are attached. I took a rod and pushed down on this circular part and the door opened. So it seems that the latch on the door itself doesnt push far enough to prop open when the handle is pulled. I want to know how can i fix this problem or how to remove that module itself off the door so i can replace it. THANKS IN ADVANCE
Remove the latching mechanism and inspect it, or post pics.
http://www.acuraautomotiveparts.org/...s=&view=normal
The Accord of the same era had a problem like this. It required drilling a hole in a specific spot on the latch to release it. Then of course, the latch had to be replaced. I don't recall where exactly that spot was but there was a Honda service bulletin on it. I'm not sure if this is your problem but sounds like it.
GL
GL
Frost7177
Oct 27, 2008 01:31 PM
