SEAT BELT ALARM CONSTINTLY GOING OFF!!!!
i took out my stock seat because they were all torn up. i got 2 3r racing seats for it just for the hell of it. now i no the alarm is going off because of the sensor in the belt harness and because its not hooked up but how do i get rid of the alarm completely. the car is a 92 integra so if u can help me out and tell me what i can do id appricate it
is there a fuse for that electrical circuit? If so, you can remove the fuse, and there won't be any electrical current running to the seat belt/ seat belt alarm circuit.
Just take your car to a certified mechanic and ask him which censor or fuse you need to disable. This is the only way to fix your problem. Please make sure the mechanic is certified.
What you need to do to disable the alarm. Disconnect the plugs from the control module which is located at the bottom right passenger kick panel. (right near the speaker cover grill).
Remove the plastic cover. (careful not to break the cover) There you will see a dull silver module with two connectors on the bottom of it. Pull them out. The whole automatic seat belt system will be disabled especially the beeping.
jebsurf
Feb 22, 2015 09:27 AM
heydella
Apr 21, 2008 09:25 PM
