Transmission & Drivetrain Gearboxes, Differentials, Clutches
Transmission Cooler built in the radiator???
Old Nov 11, 2009 | 01:08 PM
BoostedH23Accord's Avatar
Default Transmission Cooler built in the radiator???
I spoke with a transmission shop today who is rebuilding my wifes transmission and they told me the transmission cooler which is supposedly connected internally to the radiator was completely clogged and to replace it means replacing the radiator.
I'm sorry but that sounds like BS to me especially with the $300+ pricetag that comes with the radiator replacement. I have not personally looked for the factory cooler to see if it was internal to the radiator so I cannot be sure. Can someone confirm? I can't see Honda using this design but I also never thought they'd make such a crappy product in the Odyssey.
Old Nov 11, 2009 | 05:29 PM
94EG8's Avatar
Seagull Management
Default Re: Transmission Cooler built in the radiator???
Any automatic Honda I ever saw was set up the way your shop described. Cooler is part of the rad. Specifically its a copper tube that runs through the lower tank, nothing more.
Old Nov 11, 2009 | 07:06 PM
jeff652's Avatar
that is correct. trans fluid line running through bottom part of radiator. automatics only, not 5 spd. $300 is a little steep though. Tall them you'll supply the radiator and go buy one for $100. If they have the trans out, then swapping the radiator will take less than 2 minutes (literally) and shouldn't cost any extra labor . . .
Old Nov 11, 2009 | 07:25 PM
Mista Bone's Avatar
D Tranny Guru
just add a larger tranny cooler in front of the radiator.
I find it hard to believe the OEM tranny cooler is clogged.
Old Nov 12, 2009 | 02:52 PM
FerreiraCompetitions's Avatar
You can buy a tranny cooler kit for $40 at summitracing and have them put it on instead of the new rad.
Old Nov 13, 2009 | 03:28 AM
Thanks all for the responses. A friend of mine confirmed this the other day saying the Honda Technicians usually just blow it out. So I called the shop doing the work and asked what was the status...
The guy told me that they tried to use a high pressure flush method and were unsuccessful. I told him in so many words I'm not paying another $300 for a radiator and if this was his car he'd find a way to make it work. He said he'd try again and call me back with an update.
So...last night about 5:00 I get a call. Guess what, he mysteriously was able to get it flushed out. I had already planned on doing an aftermarket B&M tranny cooler once I get the van back but I needed them to fix it so I can also get their 3 year warranty. I ordinarily would pass on a warranty but in this case it just makes sense.
Once I get the van back I plan on adding a transmission cooler and an inline Magnifine filter.
Old Nov 13, 2009 | 12:55 PM
suspendedHatch's Avatar
So the question now is whether the trans is any good if there's enough **** in the fluid to clog the cooler. Just imagine the oil passages inside the tranny...
Old Nov 13, 2009 | 01:06 PM
Hence the rebuild... But more importantly the shop just called and said they replaced the VSS and for some reason it "ate" the new one up.
So it looks like we are without our van for the weekend. Ugh. My wife's gonna be pissed!
Old Nov 14, 2009 | 08:40 PM
David12's Avatar
ouch! i hope you get the problem fixed
BoostedH23Accord
10
Jan 28, 2016 10:13 PM
Wiggler
Feb 21, 2006 08:10 PM
vtecmw
Dec 5, 2005 09:44 AM
