another car wont start
98 civic with eagle/vitara setup. I was doing a 3rd gear pull on the highway. yes its tuned by a reputable tuner(sewell94) and it just cut out, everytime i touched on the gas while it was in gear it back fired. then tried starting it and all it would do was back fire and turn over. I get spark I have a see through dizzy cap and can see spark. it gets gas because of the back fires. and I know it gets air. The ignition switch was recently changed.
check the little spring thingy in the rotor, make sure it didnt come out/ snap/break. that has happened to me and i get spark and backfires, but only until i checked with my hand over the plug hole and watched the spark to see if it was in time i realized it was not. took the rotor off and found out it was broken and had turned on the distributor shaft
good luck
good luck
purplexs650d
Oct 17, 2006 12:31 PM
