Dialing in Skunk 2 Pro'1s?
Old Nov 10, 2009 | 06:35 PM
85mmek9's Avatar
Default Dialing in Skunk 2 Pro'1s?
I have been told by a couple diff people that the newer style pro1 cams you do not have to degree them? Is this true, and if so does anyone know the start of the manufacture date. I didnt degree mine and is wondering if there is more power to be made, I think there is anyways.
thanks guys
Old Nov 10, 2009 | 08:31 PM
.adam.'s Avatar
Default Re: Dialing in Skunk 2 Pro'1s?
you have to degree them regardless. its not the production process that causes this. its the fact that there are too many variables in everyones setups to just be able to swap them in and make peak power.
Old Nov 10, 2009 | 09:32 PM
Zer0_SpeedWorks's Avatar
I emailed sk2 about the "new style" pro1s and if they need to be degreed,they said they dont have any new style pro1s and you have to degree them...
[qoute]"Thank you for contacting the Helpdesk at Skunk2 Racing.
There is currently only 1 version of the Pro Series Stage 1 camshafts on the market. While there may at one point be camshafts developed with altered indexing that will be closer to factory camshafts, you will always want to degree in your camshafts in order not only extract maximum power, but to verify proper valve to valve and valve to pistons clearances as well."[/qoute]
Old Nov 10, 2009 | 11:39 PM
jdm inc's Avatar
https://honda-tech.com/forums/showth...2520138&page=2
Old Nov 11, 2009 | 03:23 AM
boosted hybrid's Avatar
I have had at least 6 cars that have dropped in the cams are 0,0 and made the most power there with the best idle. The boxes all showed "V3" on them, which is the version 3 revision of the cam that does not need to be degreed. Sounds like some of the Skunk2 employees might not know what is going on with their products?
Old Nov 11, 2009 | 03:31 AM
fmfkid250's Avatar
I think they just want cover their own ***!
Old Nov 11, 2009 | 04:38 AM
SPOOLINmatt's Avatar
I think so too, i made peak power with mine at 0,0, but a couple of tweaks from that setting helped slightly.
ive had mine for maybe 2 years at the most and dont know the revision.
Old Nov 11, 2009 | 06:16 AM
Turbo Ric's Avatar
I think the amount of adjustment will depend on how much or if at all your block was decked and head cut.
B16a2Wa
Jan 24, 2010 09:22 AM
civicsi0721
Jul 18, 2006 10:17 AM
lopaka07
17
Jul 23, 2005 12:33 AM
veilsides2000
Jun 17, 2005 08:16 PM
All-Motor H22A
Jan 27, 2004 01:25 PM
