few technical questions about my plans
ive already tried to search for this, and yes im a noob to this site, but not a noob to the scene and have worked for the local honda dealership for the last 3 years, so if you must hate please leave it off of here, i drive a 89 crx with 50k original miles, and just accuired a 94 4dr civic ex, and am planning on swapping the d16z6 and hydro tranny and also the rear disk brake settup kinda on a budget because im also boosting, so want to use as much as i can from what i have, first question is, other than the obvious, and the stainless braided clutch line, what mount is needed for the tranny? since i cant find were there was ever a hydro tranny put in an EF, and also how do i go about swapping the rear disk, i couldnt find a real good source for info on either of these problems, thanks for any help in advance!!
check out hasport.com for the d-series hydro mount.
the rear disks will fit right on, just use all your arms (toe arm, and camber arm) you can use the 94's LCA if it has a rear sway bar mount for it. if not then just your CRX ones. For e-brake cables you need to run CRX Si rear cables from what i read, everything else is too long.
integra3586
Feb 15, 2006 09:48 AM
