CRX HF Vacuum Control solenoid and CVC interchangable for other models?
Does anyone know if there is any functional difference between the egr vacuum control solenoids from other models? I want to know if I can keep my HF Solenoid + CVC to use with another motor.
the EGR parts for the H22 have different part numbers from the ones for the D15B6 - will they work? i don't know
I just need to know if there is a difference in lift values. All the solenoids should be the same as the ECU just grounds the solenoid for EGR operation
Funkin Flux
Jan 31, 2007 06:57 PM
effinnwackk
Apr 21, 2005 11:27 PM
