PA 1994 Acura Integra GSR 4 Door DB8
Old Nov 10, 2009 | 01:04 PM
thegrayghost's Avatar
Default 1994 Acura Integra GSR 4 Door DB8
173,600 Miles
VIN# JH4DB8581RS001618
I have owned this car for about 7 years. I bought the car with about 140,000 miles on it. I was putting together a turbo set-up for it, but my plans have changed and now want to sell the car. I have rarely driven the car over the past 4 years. It has been in the garage getting the following list of parts installed on it. I have driven the car less than 5000 since new parts have been installed and put back together. The car feels solid and runs strong. Shoot me an offer!
$2,950 OBO
NOTE: Anything listed as “New” has less than 5000 miles on it.
Head
-Head was hot-dipped to remove all carbon from combustion chambers & exhaust ports.
-Stock valves were cleaned of all carbon buildup and reseated.
-New Omni Power Valve Springs
-New Omni Power Retainers
-New GE Adjustable Cam Gears
-New Skunk 2 Intake Manifold (w/Type R Throttle Cable, Bracket & Intake Arm)
-New Plugs & NGK Plug Wires
-New ARP Head Studs
-New Cometic Head Gasket (Thicker HG to return to stock compression, head was milled .003)
-New OEM Timing Belt
-New OEM Cam Seals
-New OEM Valve Seals
-New OEM Valve Cover Gaskets
-Comptech Ice Box (w/Comptech Reusable Blue Foam Air Filter)
-Greddy SP2 Catback Exhaust
Bottom End
-Stock other than an Unorthodox Crank Pulley
-New OEM Water Pump
Transmission
-B16 Transmission (2000 Si)
-New ACT Streetlight Flywheel (12 LB)
-New ACT HD Pressure Plate
-New ACT Six-Puck Sprung Clutch
-Skunk 2 Short Shifter
-Energy Suspension Shifter Bushings
Suspension
-New Omni Power Street Coilovers (Adjustable)
-New Omni Power Camber Kit (Front)
-Front (stock) & Rear Strut Tower Bars
-Energy Suspension Lower Motor Mount Inserts
-Energy Suspension Bushing Kit (Not Completely Installed, will include remaining kit)
Fuel
-New Walboro HP Fuel Pump
-New OEM Fuel Filter
Misc/Lighitng/Interior
-Apexi VAFC
-Pioneer Head Unit w/3-way Speakers
-Toyota/Lexus OEM HIDs (stock projectors)
-Power Steering Removal Kit (I will include what PS parts I have if you want them)
-New Battery
-New Starter
Other
-AC & PS have been removed. I will include any parts that I have if the buyer wants them.
- I went to a civic half-rad to make room for the turbo. I have experienced no cooling issues with the smaller radiator.
-I have an extra trunk lid & spoiler for the car that will be included in the sale if the buyer wants it.
-Interior is still in great shape.
-Oil changed every 3000 with Castrol Full Synthetic & OEM Honda Filters. I just did a fresh oil change on 10/25.
The Bad
-The car needs an alignment since the installation of the coilovers. In the 5000 miles that I have driven it it’s starting to wear the inside of the front tires.
-The car has a revving/idling issue. I’m not sure if this is due to the installation of the Skunk 2 intake manifold or if it’s a sensor problem. Once you start the car it will rev from 1000-2000rpm until the car warms up. Then it will idle steady at 1500.
-The car need inspected/emissions done. I just haven’t got around to doing this. Once the idling issue is fixed, I have no reason to believe it won’t pass.
-Rear wheel wells have started to rust. Other than that, the body is in good shape with the exception of minor dings here and there.
No trades. Cash only. I will consider a check but the check will have to clear before the title is transferred and the keys are handed over.
The car is being stored in a garage about an hour away from where I live. If you want to schedule a time to look at the car, weekends would be best.
Thanks for looking!
Old Nov 11, 2009 | 04:34 AM
Default Re: 1994 Acura Integra GSR 4 Door DB8
Bump
Old Nov 11, 2009 | 10:47 AM
up
Old Nov 11, 2009 | 04:11 PM
bump
Old Nov 12, 2009 | 03:22 AM
up
Old Nov 12, 2009 | 09:08 AM
bump
Old Nov 12, 2009 | 02:22 PM
evening bump
Old Nov 12, 2009 | 04:47 PM
bolojr904's Avatar
night bump
Old Nov 13, 2009 | 06:34 AM
srt4mike's Avatar
I like white tegs.
Old Nov 14, 2009 | 04:25 AM
morning bump
Old Nov 15, 2009 | 06:38 AM
up
Old Nov 15, 2009 | 12:53 PM
bump
Old Nov 16, 2009 | 03:43 AM
Price reduced!
Old Nov 16, 2009 | 06:48 AM
killn_hajis's Avatar
how much ya lookin for it?
Old Nov 16, 2009 | 07:05 AM
$2,950 OBO
Old Nov 16, 2009 | 01:52 PM
bump
Old Nov 16, 2009 | 05:56 PM
dannysc91's Avatar
bump, my cuz just sold his for that price with about the same specs, you should be able to sell it with ease.
Old Nov 17, 2009 | 03:13 AM
thank you sir
Old Nov 17, 2009 | 03:49 AM
im not tryin to low ball ya but i have 1500 in bills? and i can throw in some car audio equipment too? sorry if that offends you thats the best i can do...
Old Nov 17, 2009 | 04:35 AM
sorry...definitely not going that low...$2950 Firmish
Old Nov 17, 2009 | 12:25 PM
up
Old Nov 18, 2009 | 05:23 AM
bump
Old Nov 18, 2009 | 07:13 AM
coupelove's Avatar
bump glws white db8 ftw!!!!!!!!!!!!!
Old Nov 18, 2009 | 01:08 PM
thank you...up!
Old Nov 19, 2009 | 03:07 AM
bump
