BAD IDLE TROUBLE BOUNCING UP AND DOWN---HELP TECHS!
Old Nov 10, 2009 | 10:53 AM
91CR-XSiR's Avatar
Icon6 BAD IDLE TROUBLE BOUNCING UP AND DOWN---HELP TECHS!
I GOTTA B16A W/JDM CTR PISTONS,. NOW IV'E HAD IDLING ISSUES SINCE THA SWAP, LIKE A FEW YEARS BACK. IVE TRIED A NEW IACV, I HAVE NO FIV CUZ THA BLOX INTAKE MAN. NO AIR IN COOLANT SYSTEM. TPS IS SET AT .5 CLOSED THROTTLE , . I DESPRATELY NEED SOME GOOD POINTERS HERE. THA IDLE FLUCTUATES ABOUT EVERY SECOND AND HALF DOWN TO ABOUT 200K THEN BACK UP TO ABOUT 1200K, WHEN WARM. PROBLEM IS KINDA INTERMITTENT. OH AND JUST TODAY I NOTICE THAT IF I PUMP THE BRAKE PEDAL WHEN THE IDLE IS BOUNCING THEN IT SEEMS TO SETTLE DOWN AND SUSTAIN ITSELF, HMMM....VACUUM TROUBLE?? .....PLEASE HELP A HOMIE OUT!!!! THANX!!!
----MATT-----91CR-X SiR
Old Nov 10, 2009 | 12:27 PM
darkintegra94's Avatar
Default Re: BAD IDLE TROUBLE BOUNCING UP AND DOWN---HELP TECHS!
check the brake booster vacuum line make sure it doesnt have a leak. or u might have an internal leak inside ur brake booster. cuz if it stops when u step on the brake then that might be it. good luck
Old Nov 10, 2009 | 02:39 PM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
Old Nov 12, 2009 | 08:15 AM
91CR-XSiR's Avatar
i thought about the booster being the problem but it never idled like that when i had my single cam Si motor in.????? can i be the check valve maybe?? ima check tha booster n e ways. thanx dark teg..
Old Nov 12, 2009 | 08:23 AM
yea check the booster valve if not check the booster hose. i have an idle problem and mine started bouncing when i let go of the brake . i check everything from iacv to fitv vacuum lines ,coolant ect u name it. up to this day i havent found the problem but heres how i get rid of it. i just drive with my lights on and it will not idle at all. its weird. but even if i dont drive with the lights on it only idles once in a while then stops. but with lights on it wont do it at all. good luck
Redprelude98
25
Nov 30, 2014 02:15 PM
blue_hatch
Feb 8, 2011 11:09 PM
Cambocheen!
Mar 23, 2009 12:09 PM
iwannaboostmyteg
Feb 7, 2004 10:43 AM
