i need 2 cluster pinouts. (tried searching)
i have an 89 civic DX hatch with a B16A and a cluster from a EF9 SiR that im going to install. i already have the plug ran for the electronic VSS. i just need to find pinouts for both clusters. ive searched, and ive found "directions" on how to swap the SiR cluster in, but they all say that you re-pin to 90-91 cluster and use the old plugs... they obviously dont fit. the SiR cluster has 4 plugs. all i need is the pinouts for both and i can figure it out myself. can someone point me in the right direction please?
here are some pictures of my clusters if it helps
here is the 89 Si cluster (does not work, the 89 DX cluster is currently installed on my car but has the same plugs)
here is the JDM SiR cluster
blasterman87
May 9, 2010 07:47 AM
