90 ef starter or ignition problem
Old Nov 9, 2009 | 09:18 PM
EF927's Avatar
Default 90 ef starter or ignition problem
my 90 civic si won't start from the ignition but when u turn the key to the on position and go under the hood and and use jumper cables from the battery to the small wire on the starter it will start that way so does anyone know my problem need the help please thanks
Old Nov 10, 2009 | 08:30 AM
fito1211's Avatar
Default Re: 90 ef starter or ignition problem
when you jumper wire from battery to small starter wire, all your doing is bypassing the ignition switch to start car. so, if your car doest start when you turn the key. you might have a faulty ignition switch. also double check fuses.
Old Nov 10, 2009 | 10:08 AM
EF927's Avatar
ok thanks alot
Old Nov 10, 2009 | 10:13 AM
D16SiHatch's Avatar
sounds like a faulty ignition switch
test it out to be sure
http://mycomputerninja.com/~jon/IgnitionSwitch.html
emv1031
Aug 21, 2013 07:28 PM
apm
10
Mar 30, 2013 08:57 PM
Jdmefsir12
Jun 30, 2012 08:27 AM
Honda Virgin
Jun 2, 2004 12:34 PM
