skunk2 pro tb sticking helppppp please
Im runnin skunk2 pro mani and skunk2 pro tb, new gaskets,original tps sensor,original iacv(original not bein new used).Car starts fine idles fine.calibrated tps correctly. Problem start wen gettin on it past 5k, idle stick @2k tap gas pedal stays stuck,pop hood n manually shut tb pulley to the right car idles fine, til i take off again,it will do it again, cant figure it out please help, oh yea sent it bak 2 skunk,they resealed it wit n adjusted sum screw.I bought it in june 09 brand new
Very common with the skunk 2 TB. Ran one and very quickly swapped it out. No need to over rev my motor because of a bad TB. Read lot's of other posts of peoples sticking too
happened to my pro series TB too. what i did was put some grease on the return spring to lube it up. solved the throttle sticking problem
you can try wd40. I have heard of people lightly sanding the inside bore of the TB. I thought about doing it too, but I just got another TB. I'm more then happy with my new one.
i used some thick grease, i forgot what type, but it was a pasty white grease i found in my garage. try WD-40, if it dont work, try something thicker
