***WINTER CLEAN OUT T1, GOLDEN EAGLE, AEBS, FCS, TURBO MANIFOLDS, BRAKES!!
most common turbos do come with a restrictor built in a 1/8" npt female fitting place inside. steel is recommended for the female fitting as vibrations for the motor will cause an aluminum or brass fitting to fail. so they use a steel feed fittings to replace them. the brass tee will work fine, the ones that break are usually in the block
