knocking on drivers side of H22a in a 93 accord
Old Nov 9, 2009 | 01:44 PM
93accdcivickla's Avatar
Default knocking on drivers side of H22a in a 93 accord
i hear some knocking on the drivers side of the block and it didnt run out of oil i am being told that the connecting rod bearings are shot other ppl telling me that the timing belt automatic spring tensioner is shot. with that said i have some questions 1. how can i tell the difference between the two assumptions?
2. if i have to do any block work might as well build the block for a N/A setup, what would be the necessary parts i would need? 350whp would be nice and my budget only allows me to build in stages so can some1 give a helping hand
Old Nov 9, 2009 | 03:43 PM
NABeastRR's Avatar
Default Re: knocking on drivers side of H22a in a 93 accord
pull each plug wire see if knock go away if it does on w/e cyl then u probably have a rod knock.
350 WHP????
you better get a bigger budget lol
350 will not be easy nor never daily driven.
biggest crank biggest cams biggest bore the best of the best ported head HIGH comression & hope for 300whp lol
Old Nov 9, 2009 | 04:19 PM
f20b jones's Avatar
what he said lol and if its a bearing your oil light should be on . 250 horse power will run 11 and is a very nice goal for a natural aspirated motor not 350.
Old Nov 11, 2009 | 10:48 AM
well my oil light is not on
Old Nov 11, 2009 | 10:52 AM
i have to check by pulling the plugs will keep u guys posted. 350whp was being funny in honda N/A talk lol
Old Nov 11, 2009 | 04:28 PM
projectTeG's Avatar
timing belt area
Old Nov 11, 2009 | 05:10 PM
NABeastRR's Avatar
my oil light never came on.
Old Nov 24, 2009 | 08:22 PM
Icon3 Re: knocking on drivers side of H22a in a 93 accord
well i tried pulling the plug for each cylinder and everytime i pull a wire the the engine stalls so much for the pull plug test
Old Nov 24, 2009 | 09:53 PM
looking to build a new motor does any1 kno the difference between a f20b and a h22 head
would it make sense to put the f20 head on a h22 block
EK FLY
Acura TSX
Jul 9, 2015 03:53 AM
hondafiend
Dec 8, 2006 09:30 AM
godsider
Feb 25, 2006 03:03 PM
ares650
Oct 14, 2002 08:13 AM
