97 Cl - accord auto trans interchange question
Old Nov 9, 2009 | 01:01 PM
racebum's Avatar
Default 97 Cl - accord auto trans interchange question
just looking for a final confirm on this. most everything i can find points to the JDM f22b SOHC vtec engine and trans that come from the accord as being a direct fit in the 2.2 CL provided the sensors are changed. has anyone tried one of the JDM trannies in the CL? do they fit? work? trying to get something solid before i do this project for a friend of mine
Old Nov 9, 2009 | 11:42 PM
racebum's Avatar
Default Re: 97 Cl - accord auto trans interchange question
has to be someone around here who's done the cheap jdm route on a CL transmission replacement...if they can
Old Nov 10, 2009 | 03:37 PM
jas_r34's Avatar
New User
i dont see why not....they both have the same engines
Old Nov 10, 2009 | 04:47 PM
racebum's Avatar
and transmission case. i verified the part numbers and they are identical. from what i've found the past couple days it's only the electronics that need to be changed over. mechanically they are compatible
Old Nov 11, 2009 | 11:52 AM
alkoholikwun's Avatar
i believe the 97 CL uses a f22bx motor, so any f22bx tranny will work. i currently am using a 92 accord ex (f22a6) tranny on a f22b sohc vtec motor. in your case, not sure about transmissions but make sure you get an OBD2 tranny. Not sure if OBD1 and OBD2 trannys vary or not.
Old Nov 12, 2009 | 02:23 PM
racebum's Avatar
from what i gather it's only the electronics that differ. the case and gearing is the same. since no true obd2 JDM engines or trannies are available what i found was
1. you need to change the distributor
2. you probably need to change vtec for the oil pressure switch just like B series
3. oil pump needs to be obd2 for the CFS
4. any electronic plug in on the trans has to be swapped with the old unit.
this of course assumes you will run your OEM USDM ecu
other than that the 94-97 JDM accord uses the same SOHC VTEC F22B as the CL with the F22B1, there is just no "1" just like the b18c and b18c1 or 5 which are country specific
endless_sugar
Sep 29, 2009 04:32 AM
technine
Apr 6, 2006 12:42 PM
JoWaY
Apr 11, 2005 11:45 PM
willyboyK20
May 3, 2003 04:47 AM
hungy
Mar 11, 2002 09:12 AM
