Help- drag racing set up on slicks?
hi guys i need some input on how to set up my suspension and tire pressure for drag at the track. i currently have 450 whp on low boost and high boost im at 615 hp. stock h22 transmission m2a4 and tien HA suspension, traction bars and 26x8 inch slicks. how should the front and back be set up and how should i launch? its a 4th gen by the way thanks in advance
You're going to get better responses in the FI forums.....
What you are asking for isn't clear cut.
My advice with suspension will be stiff rear to limit the squat and stuff front to keep the car more settled when you shift.
my springs are 12kg in the front and 10 kg in the back. also do you have to raise the back up pretty high? also what rpms are you guys revving at with a h22 gt35r 450 hp on 26x8 hoosier slicks.
AllMotorRandy
Mar 30, 2005 02:05 PM
