Honda S2000 Honda S2000
Is the f20c and the f22c heads the same?
Old Nov 8, 2009 | 11:19 PM
Fokai Drifter's Avatar
Default Is the f20c and the f22c heads the same?
is there any difference in the heads from year to year or model to model? ..ive searched and google and i cant find anything..
Old Nov 9, 2009 | 03:00 AM
esean93's Avatar
Default Re: Is the f20c and the f22c heads the same?
yes they are different
Old Nov 9, 2009 | 11:25 AM
White Smoke's Avatar
i my honda
Global Mod
Old Nov 9, 2009 | 01:07 PM
SirStig's Avatar
very different. High reving motors require balance. When drastic changes like from ap1 to ap2, you can't interchange
Old Nov 9, 2009 | 02:03 PM
JDogg's Avatar
whats different besides valve train and cams?
Old Nov 10, 2009 | 01:12 PM
4doorH22's Avatar
Just looking at hondaautomotiveparts.com I see the '02 '04 and '06 cylinder heads have different "Product numbers." I don't think you see the part numbers until you've made a purchase. Just looking at the product numbers though you could probably go into finer detail to see what else is different inside the heads. Valves and whatnot are under other categories.
Old Nov 10, 2009 | 01:19 PM
JDogg's Avatar
www.hondapartscheap.com shows part numbers
i checked 00 and 08 heads, they are different part numbers, but they include quite a few other parts so there's no telling if the actual ports or chambers are any different
Old Nov 13, 2009 | 12:40 PM
Jeremyinlinepro's Avatar
The F20 and F22 heads are exactly the same up until the Fly-by-wire throttle system was implemented.
The F22 Fly-by-wire head does not have passages in the head for the EGR system.
The valve springs are all the same installed height, spring pressure, and coil bind. In 2004 Honda changed manufacturers.
They changed camshafts when they switched over to the 2.2
Old Nov 13, 2009 | 01:42 PM
Francesco's Avatar
good info
Old Nov 15, 2009 | 01:49 PM
ITRbroham's Avatar
shit post warrior
IIRC, the MY04 F22 retainers were designed in order to remedy the MY00-03's problem of failing over time and dropping valves.
Old Nov 19, 2009 | 11:11 AM
.john.'s Avatar
yep
BryanPendleton
Feb 14, 2013 06:20 PM
shahriar35
Dec 10, 2010 09:23 AM
turboeg77
Feb 8, 2006 09:03 AM
