FS-Boosted Milano Red Civic EG
IM selling a very clean milano red eg hb. its a clean tittle.92 civic cx. The car is basically flawless, fresh paint i just buffed and waxed, and interior was detailed.
ENGINE BAY
Full wire tuck. brake lines and all and battery relocated in the trunk, inline fuel filter under the car. and all ran thru the moroso on/off switch in tailgate.
B18B1 LS SWAP
450cc blacktops
aem fuel rail with custom fuel line and fitting
walbro fuel pump
aftermarket fuel pressure regulator and pressure gauge
oil catch can
gsr brake booster and master cylinder
hasport rear mount
new spark plugs
new cam seals
perfect ls tranny
exedy stage 2 clutch
9lb flywheel fidanza
Turbo Kit
42 trim turbine, very quck and loud spool, full boost at 2500RPM
cast drag manifold
huge front mount
2.5" intercooler piping
turbo xs RFL bov
JDM sport wastegate 6psi
Exterior
very clean paint few little dings
type r front lip
rear diffuser kit
si tail lights
mudflaps
spoon cf duckbill
amber corners
yellow fogs
city light headlights
spoon mirrors
window visors
Wheels/Suspension
front gsr hubs and brakes
rear gsr disk brakes
ebc red stuff rear pads
front and rear skunk2 extended studs and lug nuts
nuespeed springs
Interior
very clean and detailed black interior
gsr shift ****
all leather door panels
boost gauge
oil pressure gauge
si cluster
stock eg front seats with ls cloths in rear
freshly repainted trunk
with red battery box and holder
c pillar bar
call or text 206 331 9736 /425-442-5737 thanks
ENGINE BAY
B18B1 LS SWAP
450cc blacktops
walbro fuel pump
oil catch can
hasport rear mount
new spark plugs
new cam seals
perfect ls tranny
Turbo Kit
cast drag manifold
huge front mount
turbo xs RFL bov
Exterior
type r front lip
rear diffuser kit
si tail lights
mudflaps
spoon cf duckbill
amber corners
yellow fogs
spoon mirrors
window visors
Wheels/Suspension
nuespeed springs
Interior
gsr shift ****
boost gauge
oil pressure gauge
si cluster
c pillar bar
blackcrx16
May 24, 2008 02:04 PM
