Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
TEIN Springs and TEIN Coilovers in stock
Old Nov 8, 2009 | 08:16 PM
RedlineMotive's Avatar
Default TEIN Springs and TEIN Coilovers in stock
TEIN Apparel
Wear Dampachi wherever you go with TEIN Authorized Apparel ...
TEIN Coilover Adjustment Wrench
The TEIN Coilover Adjustment Wrench is your answer to easy and accurate coilover adjustment The TEIN Coilover Adjustment Wrench is a beautiful piece that is an essential to any mechanics tool kitFEA ...
TEIN Damper - Type Group N
The TEIN Group N damper was developed through vigorous testing in the PWRC TEINs extensive background in Rally racing not only as a parts supplier but as a former team have culminated into the GrN dam ...
TEIN Dampers - Comfort Sport
Designed and developed with the sophisticated driver in mind the Comfort Sport Damper provides increased handling and a more stylish appearance while retaining a smooth civilized ride The Comfort Spo ...
TEIN Dampers - Mono Flex
TEIN MonoFlex Dampers The Next Level of Performance Coilovers Newly designed and developed for those core drivers seeking the ultimate in street and track performance Best suited for those drivers w ...
TEIN Dampers - Super Drift
SUPER DRIFT DAMPER is made exclusively for drifting developed for uncompromising people who would like to swing the car more freely to enjoy real drifting to the extreme andor to lower the ride height ...
TEIN Dampers - Super Racing
The Street Version Sports Shock Absorber Inherited All the DNA of Type N1 Unlimited Setting CapabilitiesFeatures TopoftheLine ReadyforCompetition Sports Shock Absorber for serious users MonoTube She ...
TEIN Dampers - Super Street
TEIN has developed advanced technology to design the shell case and stroke to bring out the full potential of your vehicleThese features of the TEIN Super Street Damper kit were designed with greater ...
TEIN Dampers - Super Street (with Upper Pillow Ball Mounts)
TEIN Dampers - Type Basic
TEIN Type BASIC damper is for the driver that is seeking high performance with a reasonable price The Basic damper MSRP starts at 75000 which includes 4 springs and 4 shocks Compared to the sleeve typ ...
TEIN Dampers - Type Euro
The TEIN EURO Damper was developed exclusively for European cars and tested on the Nurburgring in Germany A mono tube internal design and new TEIN Micro Speed Valve technology provide the ultimate bal ...
TEIN Dampers - Type FLEX
TEIN Type FLEX damper kit was designed to provide driving comfort and sports performance with its fulllength adjustment system We have incorporated separate height and preload adjustments which allows ...
TEIN Dampers - Type Gravel
Type Gravel is a shock absorber especially designed and developed for Rally racing and Rally cross It can satisfy the demands of any road surface with its 16 levels of damping force adjustment Rebound ...
TEIN Dampers - Type HG
Type HG is our suspension application and dirt trial racingIt is possible to satisfy the demands of any road surfaceFeatures Durable and reliable for gravel competition Compression and rebound dampi ...
TEIN Dampers - Type HT
We have been cultivating technology through Tarmac racing like Gymkhana and have produced HT Dampers from our knowledge Our separate compression rebound damping force adjusting mechanism makes it eas ...
TEIN Dampers - Type N1
Type N1 is our exclusive racing model application High quality is proven with high technology in the light aluminum lower bracket monotube shell case and individual compression rebound adjustment wit ...
TEIN EDFC
The EDFC Electronic Damping Force Controller makes it possible for the driver to control the damping force at the touch of a button while in the drivers seat This is accomplished by controlling steppi ...
TEIN Hood Damper
Hoods are usually made of steel The bigger the vehicle is the heavier the hood is Opening and closing the hood can be extremely troublesome especially in a case of emergency for people who does not do ...
TEIN Performance Bar
TEIN PERFORMANCE BAR is developed with high quality reinforcement using selected materials under worldclass quality control If the vehicles chassis is deformed or twisted when materials under worldcla ...
TEIN Pillowball Tension Rod
The rubber bushing of the tension rod has been replaced with pillow ***** spherical bearing in all TEINs Pillow Ball Tension Rod to eliminate tow change through compliance on acceleration or decelerat ...
TEIN Pillowball Upper Mount
TEINs pillow ball spherical bearing upper mount is designed for each individual model of the vehicle By remaining the positioning design of upper spring and shock absorber close to manufactures standa ...
TEIN Promo Products
All the fun stuff from the World of TEIN that you loveShow your Support with Official TEIN License Plate Frames Stickers TShirts Key Chains and More ...
TEIN Springs - GTech
GTECH Springs are to be used in conjunction with Gravel Type Dampers for entry level Gravel and Rally RacingGTECH Springs are sold in pairs and offered in a number of Spring Rates and Ride Heights ...
TEIN Springs - HTech
High Tech is made from a new material called Vanadium which is much lighter then other spring and increases flexibilityFeatures All spring are designed specifically to fit each car for maximum perfor ...
TEIN Springs - Standarized
Straight Type Springs We use SWOSCKV silicon chrome metal JIS standard to pursue the maximum quality of high tension and endurance for all standardized springs Stable quality endurance and high perf ...
TEIN Springs - STech
TEIN STECH Spring is an excellent step towards suspension tuningThey offer approximately a 15 inch drop for a more aggressive appearance Comes with a 1 year limited warrantySpring length is guaranteed ...
TEIN Tie Rod
Improved durability and increased steering wheel cut off angle This will allow for a higher steering angle at full steering wheel lock All for a reasonable price Tein tie rods are designed to be stron ...
Old Nov 9, 2009 | 06:01 PM
Default Re: TEIN Springs and TEIN Coilovers in stock
Thank you for your orders everyone!
Mark
Old Nov 10, 2009 | 01:03 PM
Bump it up!
Mark
Old Nov 11, 2009 | 08:25 PM
thanks for your orders everyone!
Mark
Old Nov 12, 2009 | 04:10 PM
bump it up! Thanks guys!
Mark
Old Nov 13, 2009 | 03:44 PM
Bump for the weekend!
Mark
Old Nov 14, 2009 | 06:31 PM
Thank you for your orders today guys!
Mark
Old Nov 15, 2009 | 05:41 PM
Bump it up for Sunday!
Mark
Old Nov 17, 2009 | 07:28 PM
Thanks for your orders today!
Mark
Old Nov 18, 2009 | 03:39 PM
Bump it up!
Mark
Old Nov 20, 2009 | 10:07 AM
bump for a Friday!
Mark
Old Nov 21, 2009 | 09:34 AM
Thank you for your orders!
Mark
Old Nov 22, 2009 | 05:03 PM
bump it up for a Sunday!
Mark
Old Nov 24, 2009 | 02:58 PM
Thank you to everyone for your orders!
Mark
Old Nov 25, 2009 | 02:07 PM
We will be closed tomorrow for Thanksgiving.
Hope everyone has a good day!
Mark
Old Nov 27, 2009 | 04:08 PM
bump it up for Black Friday!
Mark
Old Nov 29, 2009 | 09:04 AM
Thank you for your orders Honda-Tech!
Mark
RedlineMotive
17
Dec 10, 2010 08:38 AM
Ek9_Cuhzz
Northwest (Sales)
Jul 28, 2010 12:09 AM
CivicInspired
Honda Civic (2001 - 2005)
22
Jul 18, 2007 08:01 AM
REVHIGH
Dec 2, 2004 11:06 AM
