a6 clutch on y7 engine?
well ... i had a shop replace the clutch..and NOPE wont fit ..
so i had to order another clutch and try to pull another 160 bucks out of my ***
so 300 for labor and 160 for a new clutch for the 97 civic cx ..
anyone wanna buy clutch masters stage 2 clutch for a d16a6 lol
IT WILL NOT WORK !!! The A6 trans has 20 splines and the Y7 Trans has 21 Splines SRY IT WILL NOT WORK you need a 21 Spline clutch disc ... Pressure plate doesn't matter ..
the shafts have different splines..the y7 splines are more rounded and the a6 tranny splines are more triangle shaped... the pressure plate was to small and wouldn't come close to fitting the dowels on the flywheel ..the release bearing is completely different.. ill post pics of both of them side by side later on tonight
the d16y7 flywheel would not allow the pressure plate to bolt up . the dowels were way off .. the clutch and pressure plate is smaller for a 91 civic ..
here are the pics i said id get.. the splines are different shape that's the difference
the yellow clutch is the d16a6 clutch stage 2
and the silver oem is the d16y7 clutch
the dowel holes dont line up at all in the first pic
i placed the clutches together to show the differences
