92-95 Fog Light Help
just installed some fogs in my car and they worked for about 4 hours now every time i switch them on they blow a fuse, it came with a 30v fuse so i bought some new ones and tried to replace them but all it did was blow that fuse. any help?
Alright so I checked my grounds and they seemed all good, I dont know if this would be the problem but when I got in my car that night of the install the light on the switch went out i'm thinking maybe that's where the problem is.
if ur popping fusses it is a short to ground. not a ground connection.. trace ur power wire in the fog light harness. u have a power wire grounding out before the lamps causing a fuse to blow.. and a 30amp fuse?? way to big. a 15 maybe at the most. find out wherever they access power and follow and ull find it
traxxasx
10
Aug 10, 2009 01:28 PM
ITR.#1446
Jun 16, 2008 09:22 PM
Rex89
Oct 12, 2006 04:18 PM
EliteCivicX
Apr 10, 2005 06:07 PM
