Honda Accord 1992 Lighter socket fuse
Old Nov 8, 2009 | 04:45 PM
userix's Avatar
Default Honda Accord 1992 Lighter socket fuse
Does anyone know which fuse in the ebox is connected to the lighter socket? I am trying to find a fuse that is off when the key is in the off position and on when the key is in the ACC or ON position. I know the lighter socket turns off with the key position. Thanks.
Old Nov 9, 2009 | 12:24 AM
BlindSniper's Avatar
Default Re: Honda Accord 1992 Lighter socket fuse
i dont know what an ebox is, but the fuse i think its under the hood.
Old Nov 9, 2009 | 05:14 AM
ellewood's Avatar
New User
I am also trying to find a fuse that is off when the key is in the off position and on when the key is in the ACC or ON position.Mr or Ms.userix.if u get the solution.suggest me
Old Nov 9, 2009 | 05:50 AM
redbull-1's Avatar
It's the number 11 fuse (10A) in the under dash fuse box. Note: When you look at your fuse box, it may not be in the same direction as this diagram and you won't usually see your relays until you remove the kick panel. But, you are only accessing the fuses, so all you need to do is remove the plastic door.
Old Nov 11, 2009 | 11:44 PM
userix's Avatar
Thanks for the info. So there is a separate fuse box within the cabin of the car under the dash? I do see a radio fuse in the fuse box that is found under my hood. Would the fuse box be under the driver or passenger side? Thanks.
Old Nov 12, 2009 | 04:48 AM
chofmann79's Avatar
Drivers side, right next to where your left foot rests. There's a plastic panel that covers it up.
Old Nov 26, 2009 | 02:53 PM
userix's Avatar
What are the "options A,B,C,D" ports for? Are those switched power sources?
Crocky
Apr 19, 2017 11:03 AM
EgHatchy96
Aug 26, 2013 12:27 AM
josh_db1
Jun 12, 2010 02:46 PM
Frost7177
Jul 6, 2007 03:44 PM
