Transmission & Drivetrain Gearboxes, Differentials, Clutches
s80 tranny
Old Nov 8, 2009 | 04:43 PM
SiR eF_4door's Avatar
From: GWiNNETT COuNTY,ATL...THE STREETSz WERE WE BURN SWEETSz
Default s80 tranny
soooo i got a s80 tranny how i know if its a GS-R or LS tranny? i need to know so i can put the right price on it
Old Nov 11, 2009 | 07:07 PM
jeff652's Avatar
Default Re: s80 tranny
open it up and count the teeth.
only way to know . . .
Old Nov 16, 2009 | 08:30 PM
ramco's Avatar
It is not the "only way to know"; Everyone that messes with transmissions should know this:
put it in 5th gear, (use a screwdriver in the shift rod hole,find neutral(halfway between all the way in and all the way out), to find
5th, turn it clockwise hard, and pull back hard),now clamp a pair of vise grips on the input shaft and make a mark on the case where the handle is pointing; now count how many times the diff turns for exactly 1 turn of the input shaft. 3.46 (almost 3.5)turns is the GSR, 3.04 (a hair over 3)turns is the LS. Easier to do than to explain. BTW. those numbers are derived from multiplying the 5th gear ratio times the final drive ratio.
SA
Old Nov 25, 2009 | 08:06 PM
ramco's Avatar
5th, turn it clockwise hard, and pull back hard),now clamp a pair of vise grips on the input shaft and make a mark on the case where the handle is pointing; now count how many times the input shaft turns for exactly 1 turn of the diff. 3.46 (almost 3.5)turns is the GSR, 3.04 (a hair over 3)turns is the LS. Easier to do than to explain. BTW. those numbers are derived from multiplying the 5th gear ratio times the final drive ratio.
SA
egdriver90
Sep 13, 2009 12:40 AM
909Dc2Racer
Aug 3, 2009 10:11 PM
DSRxSALSA
Nov 12, 2008 10:54 AM
dkrex001
Jun 26, 2007 07:14 PM
See Are X
Apr 26, 2003 07:00 AM
