Finally in the 10s with peakboost powered stock b16
I went to a track that was VERY sticky, had awsome 1st and second gear with no tire spin. The day started off running a 14.1, map sensor line popping off in the middle of 3rd gear, luckly just went into default mode and limped back to the pits. Easy fix.
Head back out there for another try. Wheel hopped to a 1.85 sixty, 7.4 1/8th and a 11.0 at 130
Next and last pass:
60 1.7344
330 4.6688
1/8 mph 102.31
1/8 et 7.0528
1/4 et 10.8429
1/4mph 127.51
stock bottom end 100k+ usdm b16, arp studs, gsr cams, type r head. stock IM, peakboost gt3076r kit. 25" mh slicks on lensos. type r trans
Next and last pass:
60 1.7344
330 4.6688
1/8 mph 102.31
1/8 et 7.0528
1/4 et 10.8429
1/4mph 127.51
if you do please pm it or post it here, im looking for some one that does. i was knockin my self for leaving my camera at the house.
Congrats on the new PB.
What size exhaust housing? How much boost? Pump or race gas? How do you like the Type R tranny? What RPM's were you seeing at the stripe?
18 psi
custom blend fuel, mix it my self
i like it, i wish i had a gsr with lsd
rev is at 8900, tapped rev limit on my 130 trap
thanks for all the comments guys, im still waiting for the videos to be posted elsewhere so i can post them here
Good job dude.
I had planned on dipping into the 10.90's this year on my car. May still be able to do it. Got to fix the tranny first though. Im on a stock engine and trans as well and doing it on street tires. 235-60-15" M&H bias plys. I only got to run the 1/8th one day and knew that my 330' was sucking. Car kept wanting to bog when I hit 2nd gear. Upped the boost in that gear and it got alot better, but then rain came, and a week later my tranny went KABOOM!!!
