B16 Valve cover breather block-off?
Old Nov 8, 2009 | 12:02 PM
SolAssassin's Avatar
Icon6 B16 Valve cover breather block-off?
Has anyone ever removed the valve cover nipple on a B series DOHC VTEC valve cover and blocked it off? Might sound crazy to most, but I'm using the 2 nipples on the back of the block to run my catch can. What have some of you used?
Old Nov 9, 2009 | 08:30 AM
Default Re: B16 Valve cover breather block-off?
noone has ever blocked this nipple off?
Old Nov 9, 2009 | 01:34 PM
Innes's Avatar
yes, we blocked it off on our turbo car and will do so on the project all motor car too probably - since we have 2 bungs in the front of the valve cover and 2 on the back of the block we have no use for that at all
we just took out the nipple, welded up the hold, grinded it flat and then coated the entire valve cover once we put the new bungs in up front to still give a great look
Old Nov 9, 2009 | 02:20 PM
was it difficult to remove the nipple?
Old Nov 22, 2009 | 07:39 AM
Here's a better question:
Is this a safe practice to block this off seeing as how I'm using the "Endyn" setup?
Droolin
Nov 17, 2010 12:30 PM
migs
22
Mar 26, 2008 05:23 PM
raysjdmh22a
Oct 24, 2006 03:35 PM
