Transmission & Drivetrain Gearboxes, Differentials, Clutches
car studdering
Old Nov 8, 2009 | 08:57 AM
racingcrx's Avatar
Default car studdering
I just recently changed a worn out clutch on a 1993 accord EX. and every time I start to drive it in 1st gear the car studder's and it feels like it has something to do with the flywheel,clutch,pressure plate. But I am not sure of this. I did not take the flywheel off. all I did was replace the clutch disc, pressure plate, and throw out bearing. this happens when I am in reverse also. and the speedometer does not work. I did plug the VSS back in. what could be the cause of these 2 problems? the VSS is most likely electrical.
thanks H-T
fminusmic
14
Feb 1, 2022 05:07 PM
barron90
Honda Civic (2001 - 2005)
Feb 17, 2014 08:56 PM
quick_ls
Jun 28, 2009 06:24 AM
meltman1234
Sep 23, 2005 11:45 AM
streakz
Nov 16, 2003 06:57 PM
