16x8 et10 on a dc2??
Old Nov 8, 2009 | 06:16 AM
turbodailydan's Avatar
Default 16x8 et10 on a dc2??
been looking at a set of rota grid drift series for the dc2, only prob is they only do them in 16x8 et10.. i found a pic of a teg with them on, anyone knows whos it is??
just want to know about clearance issues etc
Old Nov 8, 2009 | 11:44 PM
Anonymous User's Avatar
Default Re: 16x8 et10 on a dc2??
those are acutally +20 offset. and i believe the owner of this car is SupaJohn
Old Nov 9, 2009 | 10:44 AM
zaccers's Avatar
Also interested, as I'll be fitting 16x8 +22 F and 16x9 +12 R.... What tire size is used on the front on those Rotas?
The rears I know I'll just have to run retarded camber along with a good roll...
Old Nov 9, 2009 | 02:51 PM
nsxtasy's Avatar
H-T Order of Merit
There is no tire size that won't rub on an Integra and can safely be mounted on a 16x9 rim.
On a 16x8, you can use 215/45-16 without problems, but it's too wide for 205/45-16. If you get 16x7 or 16x7.5, it can be used with either 205/45 or 215/45.
Old Nov 13, 2009 | 01:38 PM
Screaming Vtec's Avatar
A 225.40.16 would work ok, with minimum arch work needed wouldnt you say?
Old Nov 13, 2009 | 02:12 PM
TunerN00b's Avatar
Yes, except after searching tirerack, discounttire.com, and vulcantire.com, only the Falken Ziex ZE-512 happens to come in that oddball size.
However, for those who love the "I stuffed way to wide of a wheel on my car" look, that tire is approved for 7.5" to 9" wide wheels...
No clue on arch work, as that is a bit wider than stock sizes so offset would need to be chosen very carefully, and fender rolling/pulling might still end up being necessary.
Old Jan 15, 2010 | 06:12 PM
chivasone's Avatar
Post Re: 16x8 et10 on a dc2??
so the rims on the dc2, are they +20 offset or +10 offset cuz im looking to get some rims like those too?
Old Jan 15, 2010 | 10:01 PM
WhiteDc4Integra's Avatar
Im running 16x8s +15 offset with 205/40's, I just has to roll my rear fender's but the front's are fine and mine sit's just like the one pictured but does'nt look near as nice lol
Old Jan 16, 2010 | 01:59 AM
doekid16's Avatar
New User
Do those rims come in different colors?
Old Jan 16, 2010 | 05:00 AM
Natural Aspirations's Avatar
Originally Posted by Anonymous User
those are actually +20 offset. and i believe the owner of this car is SupaJohn
I would consult the owner afaik the only offset available in a 5x114 is +10
Old Jan 16, 2010 | 06:01 AM
DrZFiNeSt's Avatar
You should be able to run these wheels on a dc by rolling your fenders and throwing some camber.For 16x8 you can run 215/45/16 tires.
Old Jan 17, 2010 | 04:51 PM
Jvs10's Avatar
Actually, most of Falken's 205 width tires are approved for 8 inch wide wheels. That's what I'm going with on my car
edit: correction, their 205/40/16 tires are approved for 8 inch rims. Those seem to have reinforced sidewalls. Most of the others are only approved for 7.5
Old Jan 17, 2010 | 06:07 PM
chivasone's Avatar
is there a big difference if it is 16x8 or 16x7? n these r rota grid offroad right?
Old Jan 17, 2010 | 06:14 PM
nsxtasy's Avatar
H-T Order of Merit
However, 205/40-16 is too small for an Integra. On an Integra (all years), stick with 215/45-16 or 205/45-16. 205/40-16 is a good 16" size for '95 and earlier Civics, which were designed for smaller diameter tires than Integras.
Old Jan 17, 2010 | 10:26 PM
Jvs10's Avatar
Yes, I know. I was just specifying that every tire of that width wasn't approved for that width. Their 205/45s are only approved for rims up to 7.5in
Old Jan 19, 2010 | 09:59 AM
chivasone's Avatar
on the rotas, which name brand tire do they mostly come with cuz im looking to by some rota grids too.
Old Jan 19, 2010 | 10:26 AM
ok according to rota these wheels are only available in ET10, so where has this guy got them in ET20?? or has he had them machined down?
as if you look at this guys hes got them and they are ET10 and they stick out the arches big time it looks ****
https://honda-tech.com/forums/showth...2672436&page=4
Old Jan 19, 2010 | 11:03 AM
nsxtasy's Avatar
H-T Order of Merit
You can buy wheels with whatever brand of tire you want.
Old Jan 20, 2010 | 01:02 AM
Rude Awakening's Avatar
Daughter not possible
there was a guy that had these on a 5G Prelude, and I was considering them for mine. I'll have to check his specs, I want fitment like his or the first Teg, not that ITR in the link.
I brought it up in another tab...
+20 205/45
Old Jan 22, 2010 | 12:13 AM
mugendb8's Avatar
New User
Im rocking enkei 92s on my DB8.............. 16x8 ET20 fit fine. no pics ill try to get some up.
Old Jan 24, 2010 | 02:35 PM
keepinitrehaal's Avatar
+20 205/45
Cleean!!
Old Jan 27, 2010 | 08:50 AM
TekBuDDy's Avatar
shiettt, im running 15x8 205/50/15 on my db7, and i rub..
i want these rims so badd
Old May 25, 2010 | 04:57 PM
ChadB's Avatar
they look sic on the lude.
Old Jun 1, 2010 | 11:06 PM
System Lord's Avatar
i want white ones
Old Jun 5, 2010 | 07:35 AM
ChadB's Avatar
what kinda of rims are those?
