Tokico struts?
Old Nov 8, 2009 | 05:00 AM
blurry454's Avatar
Default Tokico struts?
What do you think about replacement of the stock struts on a 90 Accord with the Tokico blues on ebay? They cost 274.00. I'm on a budget and I'm considering Adding the polyurethane bushing and the Tokico struts for a better handling experience around curves. I am also trying to avoid lowering my car, thanks.
Old Nov 8, 2009 | 07:46 PM
NWaccord's Avatar
Default Re: Tokico struts?
I have the tokico blues on my 94 accord and i love them. rides real nice with the right spring
Old Nov 9, 2009 | 08:25 AM
XxMerlinxX's Avatar
Tokico Blues are considered to be OEM replacement shocks, not really an upgrade. You'll still probably notice a difference if you get these installed, but it'll probably be only because your old shocks are tired and worn out. If you're looking for an increase in performance, look at either Tokico's Illumina line or KYB's AGX line for adjustable shocks that are made for increasing performance.
Old Nov 9, 2009 | 08:38 AM
Zendos's Avatar
yeah tokico makes a good brand man you should be satisfied
Old Nov 9, 2009 | 08:54 AM
GoLowDrew's Avatar
Old Member
25 Year Member
Fair statement. I had both Blues and KYB non-adjust.
Go with the Blues. IMO, KYB was more "stock" like. At least Blues felt like some OEM "performance."
Cliff: Would not buy KYB non adjust again. Would buy Blues again.
Old Nov 9, 2009 | 03:47 PM
JSPECxSEDAN's Avatar
i say tokico illuminas.. ive had 2 sets.. one i put in my bros cd and i have the new set on mine and i love them.. of coursd im slammed tho so yeah.. but i say tokico instead of kyb..
Old Nov 9, 2009 | 05:28 PM
nicolaselias's Avatar
Loved
Community Favorite
I have tokico blues on my accord and they take a tonne of abuse on rough Trinidad roads... Also find them pretty good for my harsh driving style.. keeps things under control..
Never tried illumina but i'll look into it
Old Nov 9, 2009 | 05:54 PM
NWaccord's Avatar
ive never herd of them being OEM replacements, but their great on my ride
Old Nov 9, 2009 | 07:14 PM
nus_dogg's Avatar
I'm on Tein S Tech springs and Blue Tokico shocks. It rides nice as a DD car if thats what you're looking for.
Old Nov 9, 2009 | 08:28 PM
blurry454's Avatar
Thanks, Tokico Blues it is!
Old Nov 9, 2009 | 09:12 PM
nus_dogg's Avatar
You can check out pics in my H-T garage.
https://honda-tech.com/garage/1994-H...-nus_dogg.html
Old Nov 9, 2009 | 09:48 PM
EF927's Avatar
I'M NOT A FAN OF THEM CAUSE ALL THEY ARE STOCK REPLACEMENTS AND IF U SPEND A LITTLE MORE YOU CAN GET THE TOKICO WHITE THEY ARE MUCH BETTER AND LAST MUCH LONGER FOR THE BUCK I FOUND THIS OUT FIRST HAND
Old Nov 10, 2009 | 05:34 AM
GoLowDrew's Avatar
Old Member
25 Year Member
Last gen Surpras OEM shocks were Tokico. Tacoma continue (?) to used them. Currently I'm not sure which Toyota products still use them.
Old Nov 10, 2009 | 12:33 PM
katzenjammer84's Avatar
I've heard Koni's STR Orange's blow these out of the water, but no first hand experience with the Oranges yet.
Old Nov 10, 2009 | 02:46 PM
nus_dogg's Avatar
All I know is that the Tokico blues are not meant to go any lower than 1.5" of a drop or else you'll blow them quick. Mine's still riding nice and smooth; its almost a year now that I have them.
Old Nov 10, 2009 | 05:17 PM
Scudweiser's Avatar
i have the blues with tokico springs, about an inch of drop but they handle very well. perfect shocks for a daily driver.
Old Nov 11, 2009 | 05:05 AM
jhammond_82's Avatar
Reject Papi
yeah, i'm going with the majority here. tokico blues are a really good shock. tokico illumina's are nice too, but if you are on a budget, these are not the shock for you, lol.
Old Nov 12, 2009 | 06:28 AM
GoLowDrew's Avatar
Old Member
25 Year Member
Ditto on that. There are more choices today for a mild drop. In the old days, we are limited to (HR) Sport and Race springs (1.75-1.5, 2.25). Blues lasted about 70K miles on Sport springs. (97 Civic).
One bad shock end up damaging my tire and I had to have them all (might as well) replaced.
Two advice.
1. Keep your warranty card. I believe the shocks have a lifetime warranty (something like that). Why not make the honor it.
2. Know the life of your shocks, and watch it regularly when the time is near. Then again, this is the 90-02 Accord section and I don't know how long you'll keep your car.
Old Nov 12, 2009 | 06:57 AM
Reject Papi
friend of mine has tokico blues, idk what brand coilovers. been running like that for quite a few years now, and he has no problems. so i disagree with the fact that they are only good for a drop of so much. i've seen d2's, koni's, and other "top top" brand's fail already. its been talked about in the suspension forum already.
Old Nov 12, 2009 | 07:10 AM
19Accord97's Avatar
From what I have been reading when I was doing research, Koni yellows are #1 followed by Tokico Illuminas. Since the Konis wouldn't fit my GC's I went w/ the Illuminas. Considering they were $550 they better be good! But no problems so far.
Old Nov 12, 2009 | 07:13 AM
Reject Papi
i thought koni and ground control were the ultimate setup? your's don't fit? thats odd...
Old Nov 13, 2009 | 12:06 PM
XxMerlinxX's Avatar
I'm of the mindset that if you're only going to be riding around on the street, any adjustable shock is probably overkill. So in that case, the blues would probably be fine for what you want. As far as them wearing out prematurely, the rate of your springs are really what determine how much wear and tear the shock will see, so make sure to get a set of springs that are made for the street and not the track.
Old Nov 13, 2009 | 12:11 PM
19Accord97's Avatar
Ground Control has 3 diff versions of Ground Controls for the 5th gen Accords. One is designed specifically for the Koni Yellows and the other are for various other struts.
Old Nov 13, 2009 | 12:24 PM
Reject Papi
oh ok. that makes sense. thanks. learn somethin new every day.
PinoyDelSol
Suspension & Brakes
15
Dec 14, 2007 10:22 AM
95_civic_sparco
13
Nov 18, 2004 10:54 PM
Bryan-95prelude
Nov 8, 2004 05:52 AM
HONDA-2NR
Jan 28, 2004 06:30 PM
SMZ GSR
May 18, 2002 09:17 AM
