***making b20vtec...
yeah, then u have to tap the head and get a vtec conversion kit, its more expensive then u think, use a stock b20 head gasket though, works better.
You need a B20 Block from a CRV...and either a b16, gsr, or type r head. Thats just the beggining....you also need a type r water pump,b20 head gasket, oil pump, timing belt, and many other crap...It's alot of work. And i would suggest getting the intake manifold of the exact head that you get.
Any vtec water pump will work since they are all 22 teeth. With a vtec water pump use a GSR timing belt.
This info is everywhere posted many times
Turboholic
Jun 10, 2004 12:01 PM
