rear disc e-brake cables
yes. with because the HB and sedan are longer than the crx you can use the cables from the rear brake donor, in your case the 99-00 si. because the crx is shorter those cables are too long and will drag, in which case you WILL need the cables from a 91 crx si which are the correct length.
or to make it simpler:
88-91 Civic Sedan 90+ cables from donor car (minus del sol)
88-91 Civic HB 90+ cables from donor car (minus del sol)
88-91 Crx cables only from 91 crx si
i am not sure if the del sol cables will fit the crx. i know when my buddy attempted to put del sol e-brake cables from a del sol on his 90 HB they were way too short.
PPAW11SC
Oct 20, 2010 06:09 AM
the diddler
Feb 23, 2010 08:11 PM
spettinger
Oct 17, 2002 03:39 PM
