AEM UEGO, Display or Voltage Output?
Old Nov 7, 2009 | 02:16 PM
shawn69's Avatar
Default AEM UEGO, Display or Voltage Output?
Hi guys,
I have my aem uego wideband wired into hondata s300 and also the gauge display.
The AFR is approximately 1 point higher in Hondata than on the gauge.
Which should i take as correct??
I'm also wondering at Precision 780cc/min injector dead times, I've asked on precisionturbo.net and an employee there had replied that they only have the dead time at 13v, which is 2.128ms .
This value seems way too high, I couldn't even get my car to idle with an AFR above 10, even with offset at -100% and less than 10 in the fuel map.
So i switched the dead times to 1ms at 13v and so on.. and got the car to idle fine with normal air fuel ratios.
Thanks
Shawn
Old Nov 7, 2009 | 06:17 PM
postman's Avatar
Default Re: AEM UEGO, Display or Voltage Output?
you can offset the voltage to get the gauge and hondata afr to match. should be under closed loop in parameters if i remember right.
something doesnt seem right with th injectors. are they the correct type for vehicle. is the injectors setup correctly in hondata. could be a bunch of issues
Old Nov 8, 2009 | 07:05 AM
shawn69's Avatar
Well when the 02 sensor is unplugged they both read the same...
Yes they are the correct type, I'm using the stock resistor box. I took the deadtimes i'm using now from Vipec, which has some listed for 95lb precision injectors. And then it ran good.
Old Nov 9, 2009 | 11:04 AM
BlackT5's Avatar
Where did you ground the wideband? I had that problem when my wideband and EMS weren't grounded together.
Old Nov 11, 2009 | 06:56 AM
shawn69's Avatar
I changed my ground for the wideband to the thermostat, it is fixed now.
ThankYou!
jrock1234
Engine Management and Tuning
Feb 26, 2012 06:19 AM
OEM1
May 22, 2008 05:01 PM
V-SPEC 1
May 11, 2005 10:11 PM
kender
Sep 15, 2004 08:27 AM
LS-T
Mar 21, 2003 11:21 PM
