Function 7 sway bar bushings installed how?
Old Nov 7, 2009 | 02:01 PM
phil_lt1's Avatar
Icon2 Function 7 sway bar bushings installed how?
Hey. I have some Function 7 aluminum sway bar bushings for a ITR rear bar, and I need to know how they are installed. Which side does the tapered pieces go (inside/outside)?
Also, I'm using EM1 sway links from Moog; do I need the nut that's already threaded on, or can I take it off? Stock doesn't have a nut, just a sort of thick washer. The nut pushes the link pretty far to the outside. It makes me think I should use the far outside LCA hole on my Skunk2 arms. Thanks.
Old Nov 8, 2009 | 10:45 AM
phil_lt1's Avatar
Default Re: Function 7 sway bar bushings installed how?
Anyone?
Old Nov 8, 2009 | 08:33 PM
phil_lt1's Avatar
Nobody's used these yet?
Mikes2000civicsi
Mar 27, 2008 09:02 PM
stockredej1
Jan 30, 2007 03:58 PM
GreenBean
Feb 26, 2004 01:01 PM
Weston
May 2, 2002 12:45 PM
