HELP, major brake problem on 88 crx si
ok for like the past month my brakes have been working worse and worse, now my car is undriveable its gotten so bad, this is the problem, when i drive i can push the brake pedal all the way to the floor, there is no pressure built up at all and even once the pedals at the floor i dont stop right away, i pretty much just have to pray to stop in time, i just replaced my brake pads about 2 weeks ago to try and fix this but no progress was made, they didnt help at all, also the brake fluid is not leaking, it is still full, and the ebrake does work, anyone know whats wrong here?
Air in the lines maybe>? Have you tried bleeding them? Im not the most knowledgable person here on brakes im sure but do you hear a hissing sound coming from the mastercylinder area? Break booster hose maybe? Just possibilities. I mean, with breaks, It cant really be much. Heh, hope this helps. remember, down shift and ebrake are your best friends.
HFpower
Feb 17, 2007 04:58 AM
The Hooligan
May 5, 2005 03:32 PM
BoostedSi
Jul 29, 2002 11:09 AM
