post your race car picture and motor
here is pictures of my team our neon green project EG with bone stock h22a with no internals with one peace front end 11.5, and my car EJ with no internals with semi-build b18c1 12.5. see what ya think and post ur race car.
these car and motor are ALL MOTOR
na, for the h22 all we had is jdm lsd tran with a stage 3 act clutch, with race header hotshot header, 370cc rc, with aem fuel rail along with FPR set at 50psi with the set up of msd, using H&R 73mm TB, manifold we using is the RBC, we used spacer to fit the RBC manifold and to fit the TB. also we are running on the ecu p28 s300
for the b18c1, all we did was we put the the tri-y header, bloxs type b cams and camgear, aem fuel rail with FPR set at 50psi 370cc rc on the skunk2 manifold str 68mm tb, we used a spoon headgas, running on jdm pr3 pistons stage 3 act clutch with race pulley. p28 s200
if u say so the motor itself is stock nothing done to the inside of the motor but a little bit on the out side. beside the car only weight on 1400.
k20z1ej1
21
Oct 13, 2016 09:23 PM
BlackOnBlackTeggie
Feb 18, 2005 11:43 PM
