where is my fuel pump located
Gas tank. Look at this link for info.:
https://honda-tech.com/forums/honda-accord-1990-2002-2/92-honda-accord-fuel-pump-installation-2673778/
either an access hatch under your back seat or taking the gas tank down (unbolting the straps on the tank) should give you access. just like any other car. dont forget to disconnect any fuel lines after you disconnect the battery and whatever wires are supplying power to the pump.
You don't have access from the interior of your vehicle. The pump in inside of your tank and you need to get down your tank. If you need explanation about this procedure please write to jordanclimb at yahoo.
HybridAccord
Sep 7, 2003 10:51 PM
