Type R pistons
Old Aug 31, 2002 | 04:37 AM
migo's Avatar
New User
Default Type R pistons
What are the differences. Compression? US vs JDM ? How big of a bore cam they go. I just bought the US version and it has Black Piston skirt...What the hell does that do...Thankxs
Old Aug 31, 2002 | 04:47 AM
ZygSpeed's Avatar
Default Re: Type R pistons (D.SPECS)
The USDM ITR pistons provide a compression ratio of 10.6:1 whereas the JDM ITR pistons are slightly higher at 11:1.
The black coating on the piston skirts is molybdnum (sp) based adn is supposed to reduce friction with the cylinder walls.
The bore size needed depends on the condition of the cylinder walls, I believe the stock bore is 81mm.
http://integra.vtec.net/carboy.html
Old Aug 31, 2002 | 06:52 AM
sgT's Avatar
sgT
Default Re: Type R pistons (Zygspeed)
JDM is 11.1:1
the molybdenum coating absorbs and retains oil to help reduce friction.
Max bore 82mm on stock sleeves
Old Aug 31, 2002 | 11:43 AM
migo's Avatar
New User
Default Re: Type R pistons (sgT)
So whats consider .25 oversize
81.25mm
dunked dc
Dec 6, 2010 04:45 PM
crxfreak1117
Jul 18, 2007 07:01 AM
Racebrewer
Jun 10, 2004 11:40 AM
Halo
Dec 19, 2002 07:40 AM
raifordmotors
Dec 26, 2001 11:58 AM
