Transmission & Drivetrain Gearboxes, Differentials, Clutches
NEED ADVICE Please look.
Old Nov 7, 2009 | 07:36 AM
oneoverwrx's Avatar
Default NEED ADVICE Please look.
Took the car to the track last night and it broke about 10 feet out.
quick rundown of the car. eg coupe with gsr motor and ls trans with welded diff. On 25x8.7 slicks.
OK....passenger side axel broke off inside the transmission. Like i pulled the axel out and it sheered clean off at the end of the splines.
Question, do i have to drill the axel, tap it and pull it out or can i pull the other axel and int shaft out and use a punch to tap it out?
Thanks a ton in advance!!!!
Old Nov 7, 2009 | 10:07 AM
oneoverwrx's Avatar
Default Re: NEED ADVICE Please look.
went ahead and pulled out the other axel and int shaft. Looked thru and there is a pin going thru the diff, figures. Found my skinniest longest screw driver and tried to get around the pin, no luck. Glance over and on my table was a stock battery tie down hook thing, made it work and knocked the knub out, going to get some lunch and put it back together.
Old Nov 8, 2009 | 06:39 PM
Aquafina's Avatar
Get rid of that diff and put in an LSD. Won't break as much crap and you won't head straight into the wall when you break an axle at speed.
twkdCD595
Jul 18, 2013 12:38 PM
AllShowNoGo727
Nov 14, 2012 01:52 PM
oneoverwrx
Nov 7, 2009 10:15 AM
BeyondTheCompetition
Mar 9, 2008 05:35 PM
GSR4U2NV
Oct 9, 2006 07:03 AM
