DA Question: How do you remove driver side fender
I'm going to try and help install new door hinges on my brothers DA and Im not sure how to remove the fender to get to the hinges. Is it just unbolting all the bolts if so where are they located, if not what are the steps.
I think there are 6 or 7 bolts...sorry i dont have any pics. There are 2 or 3 under the hood. For the next 2 you actually have to open the drivers door. There is one under a little rubber thing at the top where the door and fender meet. Theres another inside opening you make when you open the door. Its about the same hieght as where the side moldings are. There is one underneath the car where you jack it up. And i believe there is one on the front of it like where the bumper is but i cant remember off hand.
Honestly removing the fender is pretty easy just take off the bolts that you can see then give the fender a tug and see where else its being held. Thats what i did and it went pretty smooth, don't worry about crazy hidden bolts cause there aren't any.
Thanks everyone I went ahead and did it this morning, went pretty easy just one bolt was tricky due to the bumper bracket on the fender being a pain the get off to get to the bolt behind it.
