1994 Honda Accord not hitting VTEC
Old Nov 6, 2009 | 08:17 PM
Major90's Avatar
Default 1994 Honda Accord not hitting VTEC
Hello,
Heres the problem:
I have a 1994 honda accord that i bought, the guy before me swapped the stock dx engine with the f22b1 vtec engine. The vtec was wired into the ecu harness, and i got a chipped p28 ecu, fixed the speed sensor, but im still being rev limited to 3500rpm. I noticed that the car has a f22b2 external coil on there, and if im not mistaking is the f22b2 non vtec distributer? could the distributer be the problem? If i were to purchase a f22b1 accord ex distributer would the looser wirings effect ecu readings? Thanks for the help.
Old Nov 6, 2009 | 11:37 PM
nus_dogg's Avatar
Default Re: 1994 Honda Accord not hitting VTEC
That may fix it too since there's a blue wire inside the distributor which is the RPM wire. So try the B1 dizzy and see if it'll fix your problem. F22B1's are internal; not external like the B2.
Old Nov 7, 2009 | 10:06 PM
civic91sief's Avatar
did he tell you anything about it having 2 step, the rev limiter of 35000 sounds like a 2 stage, which you can adjust to where you want to launch, you should look into that
Spookythescary
Mar 30, 2018 11:18 PM
projectvtec
Sep 18, 2007 01:00 PM
Uncleloto
Mar 5, 2007 10:48 AM
K i l l a B e e.
Aug 5, 2005 07:52 PM
