Final drive for h22a, 4.6 or 5.2?
Old Nov 6, 2009 | 06:56 PM
alexthegrinch's Avatar
Default Final drive for h22a, 4.6 or 5.2?
My friend is planning to get final drive for his H22a gearbox. He is planning to go for drag on his gearbox. I searched that Mfactory makes both 4.6 at 70mph 3900rpm, 5.2 at 70mph 4300rpm.
WHich final drive is well suited for a 400m drag race? Will the final drive of 5.2 be long enough to cross the finish line at the end of the 400m?
Old Nov 6, 2009 | 10:02 PM
jnv255's Avatar
Default Re: Final drive for h22a, 4.6 or 5.2?
I think that both of them are to much. I use a 4.4fd, 26in slicks, and a 9500rpm rev limit. The gear ratios on mine are different being it's a PPG dogbox, but not by much.. With the factory rims and tires it will only do mid 130s MPH in 4th gear(it's a 4 speed).
Old Nov 7, 2009 | 12:48 PM
H.Veras's Avatar
What size tires are you using? Is the car a drag only car, or is it a street car as well? How high can you motor safely rev? You have to take all these factors and more into consideration when choosing on a final drive.
1lowek2007
Apr 16, 2014 08:01 AM
577HondaPrelude
Aug 3, 2007 12:31 PM
GreenR
Jul 25, 2003 06:45 AM
se93
Jan 9, 2002 06:12 PM
