Suspension & Brakes Theory, alignment, spring rates....
Will DC2 shocks fit on a EK?
Old Nov 6, 2009 | 05:32 PM
WilC4's Avatar
Default Will DC2 shocks fit on a EK?
As the title states, will the DC2 shocks fit on a EK?? I know that the DC2 shock forks are different but i'm not sure if the top mount are different. Thanks! Sorry for spamming I'm kind of in a hurry to find out.
Will the lower part of the mounting need mods? what if i use a DC2 lower control arms? front(plus crossmember) and rear?
Will the top mount match?
Thanks!
Old Nov 7, 2009 | 01:35 PM
batallic's Avatar
Default Re: Will DC2 shocks fit on a EK?
Thanks!
if its the type r then no, but if its regular integra gsr,ls,gs, yea they'll fit, the fronts will fit right in, the rears u need to add washers since the shock forks are wider than the thin lcas on EKs
Old Nov 7, 2009 | 04:14 PM
WilC4's Avatar
really i thought that the type R and the GSR struts are the same.. whats the difference? thanks!
Old Nov 8, 2009 | 04:51 AM
batallic's Avatar
the type r shock goes into the lca, (theres no forks), gsr has forks
Old Nov 8, 2009 | 03:23 PM
fastrxu's Avatar
Tokico illuminas are the same part number for all 92-00 civics AND 94-01 tegs
The instructions say exactly what batallic said, to add washers in the rear
Old Nov 9, 2009 | 03:56 PM
tysonzane's Avatar
I'm running jdm dc2 shocks in my ek4. Had to get custom eye lca from function7 though. Everything else fits fine.
zerovandez
Suspension & Brakes
May 6, 2011 12:04 PM
DC2R82
Sep 8, 2010 03:39 PM
skipper28-DC
Suspension & Brakes
Mar 2, 2010 12:21 PM
WilC4
Nov 6, 2009 08:49 PM
AnAlbumCover
Aug 11, 2006 04:03 PM
