code 1 (o2 sensor) problem
Old Nov 6, 2009 | 05:11 PM
crx_si-r's Avatar
Default code 1 (o2 sensor) problem
ok, so as many of you guys know i had a bad idle problem a short while back. replaced vacuum lines, iacv and finally adjusted the fitv and fixed the idle problem. now shorty after i received a CEL code 1. now i have done the following:
1. replace o2 sensor with new one
2. check timing
3. re-start the ecu
4. swap out my Fuel Pressure Regulator (Per Shop manuals suggestion)
and now i still have the CEL. is there something im missing? i know when i had an adjustable FPR in my old Z6 89 HB i would get a check engine light for the same code when i ran too rich. but i currently have a stock FPR. i am thinking of installing the adjustable one now. any suggestions?
Old Nov 6, 2009 | 05:18 PM
91DBSexyTime's Avatar
Default Re: code 1 (o2 sensor) problem
i am curious as well, i did everything you did except #4, its only sometimes though, kind of annoying, i know its fuel but after 4 years its just now doing it, new fuel filter and everything meh what evs i guess.
Old Nov 6, 2009 | 07:43 PM
crx_si-r's Avatar
anybody?
Old Nov 7, 2009 | 09:56 PM
Noodler's Avatar
lol bump for this. I had a code 45 for running rich. Replaced the main o2 sensor, got code 1 and 45. i reset the ecu again and got 71 and 72, misfire cylinders 1 and 2. Reset a third time, everything went away for about 50 miles. Now Code 1 for O2A Oxygen Sensor is on.
Old Nov 8, 2009 | 07:34 AM
gringo7718's Avatar
Have you tested the O2 wiring? Run a new wire from the O2 directly to the ECU and see if that fixes the problem. (dont forget to reset the ecu)
Old Nov 8, 2009 | 07:41 AM
project91crxsi's Avatar
i have this same problem, ive just kinda learned to live with it, sic of throwing parts at it and not fixing it, dont have the money for that anymore, i replaced plugs,wires,dizzy cap, rotor, 2 new fuel filters,new pump strainer,all this helped a bit but still same thing, im thinking mines the regulator, i have it adjusted all the way up and my pressure is only at 30 psi
Old Nov 8, 2009 | 07:44 AM
crx_si-r's Avatar
my pressure is good. im at 38psi. wiring is new but im gonna recheck the solder points. im using an obd1 jumper harness so all that wiring should be good. ill check the solder points before i head out to do an oil change in the crx and EJ8.
Old Nov 8, 2009 | 09:13 AM
dacrxguy's Avatar
have you checked your injectors yet leaky injector ???? ps have you done a voltage test on the o2 to see if you are running rich or lean
Old Nov 8, 2009 | 09:20 AM
crx_si-r's Avatar
no voltage test yet. injectors are fine, if one was bad i think i would get a code 16 or 17
Old Nov 8, 2009 | 11:04 AM
gringo7718's Avatar
What is this voltage test you speak of? are you just testing if it has any output? As far as I have read, the O2 sensor shows very low voltage output and it fluctuates all the time. The only way to really test an O2 is with an oscilliscope to see the voltage cycles and fluctuation. (If you use a digital multimeter it will just constantly show the numbers changing but that wont give you any info.)
Old Nov 8, 2009 | 12:11 PM
crx_si-r's Avatar
O2 sensor voltage test I believe Are in ohms and to test it if I remember right is at idle and at wot. I think .04 and below at dle and .06 and above a wot. I was reading up on it acouple days ago in the shop manual
Old Nov 8, 2009 | 04:40 PM
dacrxguy's Avatar
its just tell you if the 02 is giving out a good signal check at idle then remove the vacuum line at the fpr there should be a significant change telling you that your o2 is capable of picking up the rich readings. its just a quick ref the oscilloscope is better(graphs) but are harder to come by
Old Nov 8, 2009 | 05:41 PM
crx_si-r's Avatar
well i checked it and all are within range. looks like its time to swap in my adjustble FPR in the morning.
Old Nov 12, 2009 | 04:42 PM
crx_si-r's Avatar
ok, just installed a Brand New Fuel Pressure Regulator and still have the code 1. im gonna swap out the current o2 sensor and see if that fixes it
Old Nov 12, 2009 | 05:04 PM
im starting to think its the ecu
Old Nov 12, 2009 | 05:13 PM
dacrxguy's Avatar
ecu does not go wrong all of the sudden and say imma throw a code one
Old Nov 16, 2009 | 09:25 AM
xseekanddestroyx's Avatar
im having a smilar probelm, throwing a code1. i just replaced the o2 sensor to see if it would fix it and reset the ecu, the nexed moring threw the same code. when i disconect the o2 sensor the car doesnt run differntly or sound different. can anyone help? thanks
Old Nov 16, 2009 | 10:44 AM
4drEF's Avatar
Keyboard Humorist
Are you running a header?
If so, try a stock manifold and see if you still get the code.
Old Nov 16, 2009 | 11:12 AM
crx_si-r's Avatar
I'm running my stock ls manifold. This light is driving me crazy. Any more suggestions?
Old Nov 16, 2009 | 11:39 AM
BiG ChOr!Zo's Avatar
cover the light with a picture until you can figure out the problem...!!!
Old Nov 18, 2009 | 04:23 PM
yea im running a dc 4-2-1. i also have the eletrical load detector code 22 not sure if this matters or not.
Old Nov 18, 2009 | 05:25 PM
crx_si-r's Avatar
ok, i swapped out the resistor box and still nothing. any other ideas guys
Old Nov 19, 2009 | 03:30 AM
idk im running a dc header also, still having the same problem, but for some reason when i get the CEL the car is way more responsive and quicker, usually ill get it at WOT and it will feel like i just hit boost as soon as it comes on, idk whats up with that
Old Nov 19, 2009 | 07:44 AM
jbrokos307's Avatar
is your o2 brand new i had the same issue untill i bought a brand new denso single wire o2 sensor
Old Nov 19, 2009 | 09:23 AM
crx_si-r's Avatar
Yea the one I swapped out was a new one, I'm running a 4 wire o2 tho
