A6 parts on Z6
Old Nov 6, 2009 | 04:11 PM
elf469's Avatar
Default A6 parts on Z6
I did a bit of research and just wanted to make sure that the flywheel, pressure plate, starter, etc..from the A6(89 Si) will work on a Z6.
From what I read, as long as the transmission is 1989+, the 20 spline flywheel, PP and clutch will work on the Z6 block.
Old Nov 6, 2009 | 05:03 PM
bprsk8r4272's Avatar
Default Re: A6 parts on Z6
i used all that stuff on my z6 came off 90 civic si swapped the front water outlet too so its at the right angle for the upper rad hose
Old Nov 6, 2009 | 06:00 PM
elf469's Avatar
ok good to know. I'm sourcing parts right now. Just want to make sure I get all the right parts the first time.
thanks for the response.
kay@neighborhoodtrends
Jul 30, 2009 03:34 PM
Xathine
Jan 13, 2008 10:37 PM
civic4dr2000
Apr 1, 2006 01:42 PM
Doug684
Dec 10, 2004 06:25 AM
